Browse Forums Renovation + Home Improvement 1 Nov 21, 2020 10:20 am We are planning a renovation and are currently looking for a builder (we have DA approval, the engineering drawings are done). We contacted fourteen and ended up with three rough cost guidelines so far (the others were never interested or we eliminated them after the first meeting). The cost guidelines range from less than 500k to 750k for the same job. I tried to normalise the variance to ensure we compare apples with apples. We still believe the average is about 20% too high. Does anyone have suggestions how to 'validate' a builders estimate? I understand they have to make a living but some of them try to take us for a ride. Thanks Re: Validating builder cost estimates? 2Nov 21, 2020 6:19 pm ChrisBirmele We are planning a renovation and are currently looking for a builder (we have DA approval, the engineering drawings are done). We contacted fourteen and ended up with three rough cost guidelines so far (the others were never interested or we eliminated them after the first meeting). The cost guidelines range from less than 500k to 750k for the same job. I tried to normalise the variance to ensure we compare apples with apples. We still believe the average is about 20% too high. Does anyone have suggestions how to 'validate' a builders estimate? I understand they have to make a living but some of them try to take us for a ride. Thanks Not sure how you can validate the cost estimate yourself, i think best to just get more quotes. With the current covid situation i was told that alot of the smaller builders are out of job and should give a better deal. Re: Validating builder cost estimates? 3Nov 23, 2020 7:00 pm On a large job like that you may be well served by an estimate from a local quantity surveyor. They are up to speed with all aspects of building and should be able to give you a realistic idea of what a job like yours should cost. Renos are hard to estimate for a lot of builders due to the nature of the beast. A simple add-on or extension is easy to work out but depending on the nature and complexity of yours, it may be more involved then you think. Do you have a comprehensive specification that they have been working from to " compare apples with apples"? " With the current covid situation i was told that alot of the smaller builders are out of job and should give a better deal." Every builder ( medium sized and small ) that I have talked to in the last four months plus a lot of other trades are flat tack with work - at least here on this side of the harbour. Stewie Re: Validating builder cost estimates? 4Nov 23, 2020 8:32 pm Stewie D On a large job like that you may be well served by an estimate from a local quantity surveyor. They are up to speed with all aspects of building and should be able to give you a realistic idea of what a job like yours should cost. Renos are hard to estimate for a lot of builders due to the nature of the beast. A simple add-on or extension is easy to work out but depending on the nature and complexity of yours, it may be more involved then you think. Do you have a comprehensive specification that they have been working from to " compare apples with apples"? " With the current covid situation i was told that alot of the smaller builders are out of job and should give a better deal." Every builder ( medium sized and small ) that I have talked to in the last four months plus a lot of other trades are flat tack with work - at least here on this side of the harbour. Stewie Agree, I don't get the impression builders are short of work on the Northshore - one third didn't even bother to respond. I accept renos are difficult to price, but all builders have been given the same information and the estimates vary by $250'000. For example one quoted $21'000 for a few steel lintels I could buy for $1'000. The same builder quoted $6'500 for termite treatment - others quoted nothing - yet this guy is a $100k cheaper than the most expensive one ... I am just trying to get a grip on what is reasonable and what is clearly a rip off. Re: Validating builder cost estimates? 6Nov 24, 2020 6:44 am Stewie D Again... "Do you have a comprehensive specification that they have been working from to " compare apples with apples"?" Stewie They all were given the same DA documentation set + all Engineering specs, plus they all came around to have a look at the property. The consensus is "yep, straight forward job". Re: Validating builder cost estimates? 7Nov 24, 2020 8:25 am A specification is a different document again. It lists room by room all the fittings etc and trade by trade what the requirements are. However, if it is a "straightforward job" as they said then it should be pretty clear just from the floorpans and elevations what was required for the overall build and any out of the norm requirements engineering wise. There will always be variations in estimates of course and some of them are going to charge like a wounded bull while others are more realistic. Stewie Re: Validating builder cost estimates? 8Nov 24, 2020 8:27 am ChrisBirmele Stewie D Again... "Do you have a comprehensive specification that they have been working from to " compare apples with apples"?" Stewie They all were given the same DA documentation set + all Engineering specs, plus they all came around to have a look at the property. The consensus is "yep, straight forward job". What you should have obtained from your designer are 1st Stage 3D bim Quantities per trade then apply realistic costs and rates, compare them with the builders quotes Ot if your builder cant tell you why there is such a huge cost difference...then he's not the builder for you... steer clear of builders lol, location tax egs, doublebay-> doublepay, Northshore-> paymore Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Validating builder cost estimates? 9Nov 24, 2020 9:06 am Thanks guys for all the feedback, this has been really useful for me to understand how this works. Much appreciated! Re: Validating builder cost estimates? 10Nov 26, 2020 8:31 am world2160 ChrisBirmele We are planning a renovation and are currently looking for a builder (we have DA approval, the engineering drawings are done). We contacted fourteen and ended up with three rough cost guidelines so far (the others were never interested or we eliminated them after the first meeting). The cost guidelines range from less than 500k to 750k for the same job. I tried to normalise the variance to ensure we compare apples with apples. We still believe the average is about 20% too high. Does anyone have suggestions how to 'validate' a builders estimate? I understand they have to make a living but some of them try to take us for a ride. Thanks Not sure how you can validate the cost estimate yourself, i think best to just get more quotes. With the current covid situation i was told that alot of the smaller builders are out of job and should give a better deal. How do you know the cost is 20% too high or is it just your wish list it should be lower. The best cost estimate is economic reality, what the builders will charge to get the job done. I am a QS and I can tell you that it does not matter what estimate I come up with if you cannot get the builder to build it for the less than theirr price. All you can do is ensure that your instruction set to the tenderers is clear and simple and carefully select who you invite to tender, that means research. Ultimately a well conducted tendering will result in realistic offers, if then it is too high your project and specification will need a haircut. Beware of tenders that are way too low, you won't get quality or performance. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Fair Trading can issue orders to rectify and complete but once the matter goes to NCAT these orders are automatically vacated. You will have to terminate contract and sue… 21 29709 How are you doing Ben? Extremely interested in hearing what you are doing or plan to do! 12 15156 custom probably not. Volume, most defiantly, but spec would vary. If youre doing a knock down, there additional costs associated with that that will eat into your budget… 1 10275 |
