Browse Forums Renovation + Home Improvement 1 Nov 20, 2020 9:30 am Hi, my hot water system is a Dux Proflo and its in a cabinet in the laundry, the cabinet inside gets very humid to the point the cabinet door fixings and hinges have rusted, I live in a humid climate.. should I add vents to the cabinet doors to vent it out and if so will it raise the humidity of the house? or anything I can do to keep the humidity down inside the cabinet without turning my whole house into a greenhouse withh mould the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13767 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20228 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
