Browse Forums Renovation + Home Improvement 1 Oct 21, 2020 11:09 am How do I get the correct finish on an interior brick wall in which I have filled a hole? I patched it with Builders Bog but as expected, when sanded back it is a smooth finish as opposed to the tactile finish of the original wall, which I assume is a type of render. Thanks in advance! Re: Restoring Correct Finish to a Patched Interior Brick Wal 2Oct 21, 2020 7:14 pm Use a 1:4 sand/cement mix, throw it on with a steel trowel, use a timber screed to scrape off the excess then a wetted sponge float to finish it off. Stewie Re: Restoring Correct Finish to a Patched Interior Brick Wal 4Oct 22, 2020 8:40 am Stewie D Use a 1:4 sand/cement mix, throw it on with a steel trowel, use a timber screed to scrape off the excess then a wetted sponge float to finish it off. Stewie One clarification - given that once the hole is filled and sanded (small screw holes from where a shelf was attached) the filled hole is flush with the rest of the wall. Won't this technique result in a protruding surface at this point (ie. a local bump)? Also, given it is such as small area, using a trowel would be difficult or is it ok to spread it out over a larger area over the unblemished surface? Thanks. Re: Restoring Correct Finish to a Patched Interior Brick Wal 5Oct 22, 2020 8:44 am You didn't say it was a screw hole! Just use the builders bog and go over it a few times to get the surface flush. paint the whole wall a couple of times and if you've done a good job of the patch you shouldn't be able to notice it. Stewie Re: Restoring Correct Finish to a Patched Interior Brick Wal 6Oct 22, 2020 8:47 am Stewie D You didn't say it was a screw hole! Just use the builders bog and go over it a few times to get the surface flush. paint the whole wall a couple of times and if you've done a good job of the patch you shouldn't be able to notice it. Stewie Sorry! I was asking in a more general sense as I do have larger holes to fill as well so your advice will be put to good use. We'll paint over it a few times with the roller and hopefully it comes out looking good. Cheers Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 8006 I am looking for someone who might have tackled a similar issue as me. I have a few rendered interior walls, the surface condition is hardly flat. I can see all the bumps… 0 8032 Hi Would love some advice on a DIY project I've dived into that's now keeping me up at night. We've got a cool 1970's Mid Century style house here in NZ and have always… 0 4073 |
