Browse Forums Renovation + Home Improvement Re: Lining a shed 9Feb 08, 2022 9:53 am MClark Mcblt arcadelt Ours is a full timber frame fitted inside the steel supports. We primarily wanted it so the corrugated cladding could run horizontally, but it means we can insulate and line the shed if we wanted too. Thanks for the photos! Really helpful. MClark Can be done no worries, you would need to resheet the roof and get some parking up there, build insitu walls insulated and lined. There is a bit of work involved but nothing crazy. Where are you located? That sounds like a lot! I’m in Adelaide. Bugger, if in Melbourne could have dropped in. It isn't alot when you break it down item by item. If I am lining a shed ceiling like the one OP has shared, would it require battens between the purlins? Or can I get away with just attaching directly to the underside of the purlins? Spans are 900mm, sheets would be 900x1200x10mm for ease of installation. Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3716 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 14083 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2590 |
