Browse Forums Renovation + Home Improvement 1 Sep 30, 2014 7:07 pm Hi guys, I'm looking to build a permanent Alfresco on the side of my townhouse. It will be undercover with a tiled roof and I basically would like to deck it out with an area equipped for a BBQ including rangehood and a sink for food preparation. Unfortunately a main sewer pipe runs through my property and I have been told by South East Water that I am able to build the Alfresco however, I will need to remove the BBQ/kitchen from the design otherwise it will not be approved. Apparently, they do not allow for a sink to be build within close proximity of an easement. Does anybody know what the reasoning for this is? Can anybody give me suggestions for an alternative as i am not able to plumb a sink near the main sewer pipe? Re: Alfresco with kitchen 2Oct 07, 2014 1:21 pm Hi Pedestrian, If you are building over an easement, which it seems you are, then buildings in that situation must be class 10 I think. Verandahs, and sheds and carports are OK but not habitable rooms I think. Hope this helps, Leonardo_23 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4484 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 5820 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 2338 |
