Browse Forums Renovation + Home Improvement Re: Demolishing masonry wall 3Oct 14, 2013 6:15 pm Stewie D Is it a load bearing wall ? Stewie Hi, I think "free standing" probably implies it is not. In that case a lump hammer would do it brick by brick (less messy), or a hit or three with a sledgehammer if mess and flying bits of brick are OK. Start with the less supported bricks at the upper outer corners and work your way down. Cheers Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6290 ok thanks - yes was wondering if that should have been listed as Option Three! 2 8100 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4605 |
