CCTV Upgrade help and advice
We had a system installed a few years back
Its a Dahua 8 channel DVR XVR5108HS
And we are running 8 cameras with the older connection type HDCVI
7 of them are 2 megapixel DAHUA
1 of them IS 3 megapixel TRUVISION and is far better than the others
The DVR is extremely noisy. It can be heard from almost anywhere in the house and its hidden in a broom closet.
The camera quality is not great even in Daytime we really want a better system
We have had a few crimes in the area and if we had better quality at the times We could have identified some people and vehicles
What options would we have for an upgrade ?
Given that all the cables are in place Either keeping the existing cables and get a new DVR with new cameras?
Or changing everything to I.P. system ?
If I have to spend a bit more I dont mind i'd rather get something good for long term
Plus I am home for the next 4 weeks so can potentially do it all myself. Either using same cables or pulling new cables through
I am not an expert so i dont understand too much of the technical
Could I get some reccomendations please ?
If you could add links on where to buy would be great also
Thanks in advance !
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
29/05/2023
10
Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy…
