Wireless vs Wired home alarms?
I am about to do a new house build and i am going through the electricals with my builder.
I'm building a double storey house and I'm just wondering, is it worth doing the home alarm pre-wire or are wireless home alarm solutions good enough?
What are your experiences on wired vs wireless?
Anyone heard about wireless home alarms being jammed by intruders?
Thanks in advance.
hth
Hi All,
Thanks in advance.
Thanks in advance.
I will always prefer wireless security system as wired security system can mess sometimes if not installed properly. If you prefer to choose hardwired security system, you need to be very careful about the installation and placement. Don't know if electrician can pay so much attention while installing. A wrong placement of detector for example if it is in front of your window, it will set the alarm off every time vehicle passes by. Get a licenced technician to install it.
No batteries to change, no range issues
Use a security installer not an electrician, security installers need to be licensed in most states, so check as each state has its own requirements.
I do agree that get a professional security company to have a look at the placement of the detectors.
I initially suggested a few locations which I think is suitable but the professional changed it and explained to me. All are great reason.
7
Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out…
3/03/2024
5
We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we…
9/05/2023
4
go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages…
