Securing a Garage Door?
BUT - remember to unlock before use.
But as you say - critical to remove before repowering the door - may have to put a note to myslef on the switch
that is wired into roller door circuitry
when motor is operating solenoid is retracted from locking door
when motor is not operating solenoid locks door in closed position
Two folding latches secured into the concrete and attached to the bottom of the door is best. Disengage the motor mechanism every time you lock bolts, and you'll never stuff anything up.
hi i am discussing the tips to prevent breakage
1) do not leave the garrage door remote in your vehicle.
2) Invest in a keychain remote opener – Stop using that remote you clip to your visor and get a keychain remote opener that you can leave on your keys.
3) Secure your garage door emergency release
4) Keep it locked – Put a deadbolt on the door between your house and garage;
5) Make sure the door from your garage into your house is as secure as your front door
6) Install a wide-angle peephole in the door between your house and your garage – You’ll at least be able to see what’s going on if you hear a strange noise; rather than opening the door to find out.
7) Frost or cover your garage windows – Don’t do thieves any favors by enabling them to see when your vehicle is gone, a better idea would be to replace the door with one that lacks windows.
Padlock the throw latch on your garage door when you’re out of town – If you don’t have a manual lock on your garage door, you can use a c-clamp tightened down on each side of the door track to effectively “lock” down the door. It’s similar to those small window track locks you can buy for your home interior windows.
10) Don’t neglect maintenance on the mechanical parts of your roll-up garage door and keep an eye out for corrosion. Don’t forget the door from your garage to your house; check the frame, locks, hinges and any replaceable items.
if you keep this things in mind you really need not worry
and set the home location on your gps to a landmark near your home, so if someone finds your keys they can try nearby cars until it unlocks, then use your gps to drive to your house with your front door key
Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I…
15/12/2023
Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture.
20/02/2024
My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and…
