Browse Forums Safer Living Re: CCTV for Home Security 2Aug 21, 2015 8:30 am If its double story then yes you should pre wire while building. If its single story you should be able to do the wiring post handover. Dont bother with analogue cameras, run Cat6 cable to where you want each camera and then buy a good 2MP-3MP IP Camera, if you get a POE switch you can power the camera off the same cat6 cable. If you hunt around you should be able to get Hikvision 3MP cameras for about $150 if you grey import them from china, locally they retail for about $260. Re: CCTV for Home Security 3Aug 21, 2015 8:42 am Even if you have a 2 story, depending on where you want cameras, you might be able to do cabling after, eg if you're only putting them in eaves. Otherwise get it done pre. Also you don't need a POE switch if your NVR has POE. Get pOE IP cameras for sure. Get all the cables terminated where you will keep your NVR. Ours is in a linen closet. Buy all the components on eBay or aliexpress. Look up camera reviews before you buy any though. All the advertising looks great, but there is a lot of crap out there. If you need more advice we'll need more info Creator of superduperonium, expert at expert things, nobel laureate, can hold my breath for 10 minutes. Re: CCTV for Home Security 5Sep 26, 2015 12:06 am For a more straight forward installation free of any potential issues, pre-cabling is advised. I recommend getting your pre cabling done by the person who will be installing the cameras, it can result in a neater installation afterward. If it is a double story house, pre-cabling is highly recommended. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20651 It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8505 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9792 |
