Browse Forums Safer Living 1 Jul 11, 2013 6:30 pm Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Security screens and window cleaning 3Jul 13, 2013 1:21 pm Build thread: viewtopic.php?f=31&t=65085 Re: Security screens and window cleaning 4Jul 13, 2013 1:24 pm ~ Anne I used to be indecisive but now I'm not quite sure. Eeek - We're embarking on a knockdown rebuild! Click here for our build thread Our blog: kdrhome.wordpress.com Re: Security screens and window cleaning 5Jul 14, 2013 9:27 am Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Security screens and window cleaning 6Jul 14, 2013 10:09 am Build thread: viewtopic.php?f=31&t=65085 Re: Security screens and window cleaning 8Jul 14, 2013 5:30 pm Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: Security screens and window cleaning 9Jul 14, 2013 5:36 pm ______________________________________________________________________ Signed up Jan 2013........Almost done! My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=65763 Re: Security screens and window cleaning 10Jul 14, 2013 6:42 pm Build thread: viewtopic.php?f=31&t=65085 Re: Security screens and window cleaning 14Nov 17, 2014 12:55 pm If the windows cannot be removed, be it the panes or the frames, then I do not think there is any way you can access the middle screens. If the dirt you mentioned is not that visible, then I think you should not even bother to have the screens cleaned. Here in my storage facility, we just clean briefly so as not to look weathered, but it still gets dusty every now and then which is common and normal. Re: Security screens and window cleaning 15Nov 17, 2014 1:39 pm I have found spray on stuff at Bunnings. It is in a weed n feed type container and you wet the window (through the screen), spray the soap foam stuff on, leave it for 10-15 secs and spray it off again. Brilliant. ______________________________________________________________________ Signed up Jan 2013........Almost done! My thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=65763 Re: Security screens and window cleaning 16Nov 17, 2014 6:34 pm It is best if you remove first your screen and wipe it first with clear water to keep out the moist out of it. Re: Security screens and window cleaning 17Nov 26, 2021 3:19 pm Di Nosaur I have found spray on stuff at Bunnings. It is in a weed n feed type container and you wet the window (through the screen), spray the soap foam stuff on, leave it for 10-15 secs and spray it off again. Brilliant. What's the name of the product, please? Re: Security screens and window cleaning 18Nov 26, 2021 3:20 pm danielsimoons It is best if you remove first your screen and wipe it first with clear water to keep out the moist out of it. The screen can't be removed at all, it's a bolted security screen. I have the same problem, trying to find a solution for cleaning the glass behind the screen Building Standards; Getting It Right! We are building on a zero-lot. The first-floor windows on the zero-lot side is 1.2m away from the boundary. There are 3 windows on that side of the house in the first… 0 1057 Hi everyone. I am a single mother with little daughter, living in a small tourist town in WA Australia. I am thinking to install security screens to all the doors and… 0 22737 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9780 |
