Which CCTV system would people recommend.
Haven't heard anything about Pacom, is it any good?
I've heard Bosch is good and Samsung has better cameras...
Which one to choose?
Also would you recommend analog or IP cameras?
Browse Forums Safer Living 1 May 08, 2013 12:28 pm Which CCTV system would people recommend. Haven't heard anything about Pacom, is it any good? I've heard Bosch is good and Samsung has better cameras... Which one to choose? Also would you recommend analog or IP cameras? Re: Pacom, Bosch or Samsung CCTV 3Apr 25, 2016 8:25 pm OK this is a very hard question to answer. Bosch and Samsung both have different lineups each of varying quality vs price so it depends what you are trying to measure and compare. Historically Bosch has always made top notch high quality products and is considered one of the leading brands. Swann provide consumer/budget products and many of their cameras are re-badged, I would only go for their higher end stuff, quality varies but generally make good products all round. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: Pacom, Bosch or Samsung CCTV 4May 12, 2016 10:03 am I prefer Hikvision and Dahua. Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Re: Pacom, Bosch or Samsung CCTV 5May 28, 2016 12:29 am If your on a budget or looking for cheap but good, I would agree with syautd with the Hikvision gear, they are really doing good things, just make sure its genuine, there are a lot of fake ones floating around that you cant update firmware, etc.. The newer Swann gear is actually rebadged Hikvision from what I am hearing and seeing, so you could always weigh up the options and prices. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20704 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2725 |
