Pacom, Bosch or Samsung CCTV
Haven't heard anything about Pacom, is it any good?
I've heard Bosch is good and Samsung has better cameras...
Which one to choose?
Also would you recommend analog or IP cameras?
Bosch and Samsung both have different lineups each of varying quality vs price so it depends what you are trying to measure and compare.
Historically Bosch has always made top notch high quality products and is considered one of the leading brands.
Swann provide consumer/budget products and many of their cameras are re-badged, I would only go for their higher end stuff, quality varies but generally make good products all round.
The newer Swann gear is actually rebadged Hikvision from what I am hearing and seeing, so you could always weigh up the options and prices.
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
31/01/2024
I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to…
