An installer said you still need to have a licence even you install a wireless alarm system for DIY.
Is this correct?
Are wireless systems technology any good now?
Where can you get some in SE Melb?
Browse Forums Safer Living Re: Licence required to install Alarm system? 2Dec 11, 2012 7:27 am I would doubt this. It is not my area, but I doubt it. cheers Re: Licence required to install Alarm system? 3Dec 11, 2012 8:08 am My understanding is that you can install for yourself, even a wired one, as it's all low voltage. The mains connection, if not a simple plug into a GPO, will need to be done by an electrician. If you want to install for money (i.e. charge for a service) then you'll need a license. If your system connects to the telephone network then you'll need a license (even if it just plugs in). Insurance companies may not recognise a self-installed alarm. They usually only recognise alarms that are monitored (i.e. provide a discount) by a professional company. An alarm monitoring company may not wish to monitor a self-installed alarm. I am self-installing a wired alarm (Ness M1) and will have an electrician install a GPO inside my alarm cabinet for connection. Re: Licence required to install Alarm system? 4Apr 25, 2013 11:31 pm Just done a Open registration course that talks about phone cabling , alarm sysyem installs and here is the latest. You need an alarm instllers licence to install an alarm that has the POTENTIAL to be connected to a phone system. Note the word POTENTIAL! Even if you DO NOT have it hooked up to a telephone system but it has the CAPABILITY to be linked, then you need a licenced installer. Re: Licence required to install Alarm system? 5May 01, 2013 7:29 am In most (all?) states you need a security license to install alarms - this is an issue of consumer protection, to prevent criminals and the like from operating in the security business. For DIY I wouldn't be too concerned about this part - you aren't planning to rob your own house. For a wireless alarm, you don't need a cabling registration as long as the alarm unit simply plugs in to an existing socket and has an A-tick (so it is permitted to connect to the telecommunications network in Australia). If an alarm has wired sensors etc then you need a restricted cabling registration (as a minimum) in addition to the security license. That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8646 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 5458 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2132 |
