Okay, you guys had me worried quite a lot for a while there!
Browse Forums Safer Living Re: Stolen hot water system. Security ideas? 25Mar 12, 2013 9:24 pm so its obvious that trades are pinching them is it ! I would suggest that its just jerks that are selling them in pubs & not for any particular job at all. There are such things as serial numbers & builders are now recording them on install. the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12359 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9780 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20219 |
