Browse Forums Safer Living 1 Oct 12, 2011 12:12 pm G'day all, I've purchased an "NX Series Code Pad NX-1508 8 Zone LED Code Pad" with the view of adding this to the Hills R8 System we have already installed. This should in my opinion be a simple job of attaching the new (extra) codepad to the board at terminals 9 - Data, 8 - Com & 7 - Pos. Is there anything else I need to do in terms of wiring? I've done this in the past with a DAS 2500 system, which isn't too dissimilar to the R8, and that was as easy as connecting the new codepad to the terminals on the board - can't see why this should be any different. Thanks all. Dave. Re: Extra CodePad for Hills R8 Alarm system 2Oct 12, 2011 9:40 pm That is all you will need to do for the wiring, but in the programming you will need to change the code pad number so it will be 2 instead of 1, it's in the installation manual if your not sure how to. Re: Extra CodePad for Hills R8 Alarm system 3Oct 13, 2011 8:21 am Thanks for that, if I'm reading this right, I need to enter *94 on the new codepad, followed by the "enter programming code" numbers, enter 2 for the second codepad, Press *.. it then asks to set the Area Number, which for the R8 is by default 1. Hope this is right? Re: Extra CodePad for Hills R8 Alarm system 4Nov 03, 2011 6:52 pm Easy As... Connected the three wires, reprogrammed from scratch - as my installer changed the "Go to Programming" code, tested and working like a charm. The programming is fairly easy once you get the hang of Zones, Areas, Segments, and segment values. Thanks TUBBYM! Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11015 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3646 |
