How Secure Can Breezeway Glass Louvre's Be?
Size of opening will not be huge. They will be between 400-500 wide and about 700mm high. Big enough to squeeze through. I intend to use laminated glass but cannot see them being too hard to remove/break.
Any ideas. I will have fly screen mesh over the openings. How strong can this be?
Cheers
We have louvres throughout our new house. When they are closed they are impossible to open without breaking the glass. When they are open, however, it is very easy to remove the glass panes from the inside and only slightly more difficult from outside. Ours are all upstairs so I'm not too concerned but I wouldn't leave them open if they were downstairs without security screens or an alarm system.
Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you
26/10/2023
1
What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only…
