Browse Forums Safer Living 1 May 24, 2010 9:25 am Hi, I am planning to build Carlisle Oxford 23 house without seeing a display home. As I know they don't have one for display. If someone out there already built this house or building at the moment, can you please advice? I am bit worried about the main entrance corridor. Is looks bit narrow on the plan. Thanks Re: Carlisle Oxford 23 house 2Aug 11, 2010 7:18 pm home_ lover79 Hi, I am planning to build Carlisle Oxford 23 house without seeing a display home. As I know they don't have one for display. If someone out there already built this house or building at the moment, can you please advice? I am bit worried about the main entrance corridor. Is looks bit narrow on the plan. Thanks just finished building the Oxford 22.. it does look narrow in the plan but upon seeing it, it's alright... not sure if i got pix on my blog.. good luck with the build.. you might want to also visit the Carlisle Homes thread here in H1 Oxford 22 @ Stage12a Point Cook Site Cut : 05/03/2010 Slab Pour : 24/03/2010 Frame Inspected : 06/04/2010 Pre-plaster Inspection: 22/04/2010 PCI: 16/07/2010 Final Inspection: 30/07/2010 Landscaping: who knows??? MyHomeoneThread Our Oxford22 Blog We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37143 Carlisle use to sneak a water resistant "Performance Solution" into their contracts. Have you checked your contract for same? 4 10221 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7031 |
