motion sensor or low wattage light
I am looking to install some lights for security at both front and back yard.. Would it be better to install motion sensor lights (typically using 150W globe), or should I get the electrician to install a new light fitting that could use small wattage bulbs (LED / energy saving - 5W) and have it turned on the whole night ?)
Also, does anyone with experience on using solar LED security lights ? Is it bright enough to do the work ? (it can save me hefty installation cost since its DIY)
Thanks
go with the sensor lighting! led lights are not very good at lighting up say a whole yard if an intruder was to hop your fence.
a 150w double sensor flood work great, and are easy to install. they will light up a whole yard
1
I'm curious, did they provide any reason why they did not like the idea?
23/07/2023
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
