Browse Forums Safer Living 1 Mar 06, 2010 5:40 am Hello All, I have seen some alarm systems that alert you by text message when there is an intruder in the house. What are you meant to do when that happens? Go home and stop the intruder or call the police, but then it may be a false alarm? Im just a little bit confused! Victoria Re: A question about alarms sending text messages 2May 25, 2010 11:45 am normally these same alarm systems can be monitored to call a secuirty company when triggered. if you dont want to pay a monthly monitoring fee and perhaps work close to home then you can configure them to call or sms you. what you do then it up to you and probably depends on the time of day, where you are and perhaps who your with when u recieve the sms. the other advantage is most of these systems can also be connected to your smoke alarms and can send a different sms message if the smoke alarms are triggered. in which case you rush home and investigate. i only work 5mins from home so knowning if my smoke alarm has been triggered gives me peace of mind. Re: A question about alarms sending text messages 3Jun 04, 2010 4:28 pm Victoria_g06 Hello All, I have seen some alarm systems that alert you by text message when there is an intruder in the house. What are you meant to do when that happens? Go home and stop the intruder or call the police, but then it may be a false alarm? Im just a little bit confused! Victoria You have the right to be confused... I had a system installed 10 years ago that called you with a voice message. I got a call from the system not long after I moved in, however I was on the other side of the country. At the time I had no neighbors so I had no idea what to do. If you call the police they won't do anything after all they are not, contrary to belief a public security company. In the end I had to get my sister to go after work to have a look only to find it was a false alarm. Suffice to say when I got home I re-programmed it to remove the call me feature and now I just use the alarm as a deterrent. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
