Browse Forums Safer Living 1 Dec 03, 2009 5:14 pm Hi Guys, We have sent off for several alarm quotes, and have had only 1 reply ( Must be because of the silly season) We are based in WA Can anyone advise whether the quote is good or not. BRAND: Is Reliant 1 X NX128 12 ZONE ALARM MAIN PANEL 1 X NX ICON LCD CODEPAD 1 X 7 AMP HOUR BACK UP BATTERY 1 X 16 VOLT AC POWER SUPPLY 2 X INTERNAL SCREAMERS 1 X EXTERNAL SIREN / STROBE COMBO UNIT 1 X 4 BUTTON REMOTE FOB KIT INCLUDES 2 REMOTES WITH CONNECTION TO BOTH FRONT GARAGE DOORS 7 X QUAD PIR INTERNAL INTRUSION SENSORS / FRONT ENTRY, MASTER BEDROOM, MAIN LIVING AREA, REAR HALLWAY AREA, HOME THEATRE, 2 X GARAGE (to protect the toy) 1 X MODE 3 TELCO POINT 1 X SMS MODUAL ----------------------------------------------- TOTAL $2,980.90 Thanks Re: Is this alarm quote reasonable. 2Dec 09, 2009 3:19 pm Hi Mayjay, I belive this alarm for a house. isn't? If yes why do you need a NX128 12 zone panel its too much for a house. For the below mentioned spec a NX 16 would be enough. From my experience I would say the quote is too much.. Can be done with AUD2000/- This is what i got:- Bosch Solution16i LCD code pad 7amp hour backup battery 5 PIR sensors 1 internal screamer 1 external screamer 2 remote sms module Mode 3 dialler for 1250/- Seems good to me. I've been told $4-5k/sqm is reasonable in Perth. 2 11189 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20922 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14333 |
