Browse Forums Safer Living 1 Sep 25, 2009 10:07 pm If you go out and put the alarm system on, what happens when you leave the cat indoors? Would it set your security alarm off when it goes for a walk around the house? Re: May be a daft question but ...... 3Sep 25, 2009 10:10 pm It depends on the alarm, some you can change the sensitivity so a cat will not set off the motion sensor. Re: May be a daft question but ...... 4Sep 26, 2009 8:42 am ozzybird If you go out and put the alarm system on, what happens when you leave the cat indoors? Would it set your security alarm off when it goes for a walk around the house? Our alarm has pet-aware PIR sensors, so the theory is that the dogs and cats should not set it off. We'll find out once we move in. Re: May be a daft question but ...... 5Sep 29, 2009 7:15 am Thanks for your replies I need to check our alarm to see if it has a pet-sensitive thingy. See, it wasn't a daft question after all. Joe, it depends on your certifier but we are noticing the ones we deal with are really cracking down. So i would recommend you follow your approved landscaping plans to… 4 10853 Hi Simeon, Thank you for laying it down for us. Makes sense. Appreciate it very much. Have a nice day. Cheers 2 8957 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3476 |
