Browse Forums Safer Living Re: Home Security: Perimeter System = recommended? 5Jun 16, 2009 1:22 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Home Security: Perimeter System = recommended? 7Jun 17, 2009 5:19 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Home Security: Perimeter System = recommended? 10Oct 25, 2009 9:56 am I will keep this simple because i agree with the last couple of posts. Reed switches are a waste of time and money. I would put a garage door reed on or put a PIR in the garage. I prefer just putting PIR's in rooms that you will have valuable stuff that is easy to move. Generally this means 4-5 Pir's. Than just buy some security lights to go around the house. Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12533 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12795 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9798 |
