Browse Forums Safer Living 1 Mar 11, 2009 11:28 pm zazz are doing it again. this time it's a security monitoring system.
swann brand again. Swann Security Monitoring System 4 CCTV Night Vision Cameras & B&W Monitor Auto Switch between 4 Cameras! $129.85 (including GST) +$14.95 shipping Re: swann monitoring system 2Mar 14, 2009 7:06 am You get what you pay for.
I bought a $300 camera with a Sony CCD which is very clear, but daytime only. I bought a $95 Sharp CCD night vision vandal proof camera of Ebay and its great. I then bought another night vision vandal proof for $65 and its crap. I have just bought another for $120 and its better again. A mate of mine bought a pack from Ebay very similar to the Swann setup and its ordinary. Its CCTV on the cheap for the masses. Normally CCTV costs big dollars for the functionality of pan, tilt, zoom, resolution and recording. It doesn't need to be a massive cost but you should try for quality of you can. I started with one camera going into the starserve. With out starserve, you can buy a modulator for about $65. so one good camera and a modulator to go to your normal tv will be around $160 plus cables. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19497 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9780 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12402 |
