Browse Forums Safer Living Re: CCTV through builder or leave it until handover? 3Feb 16, 2021 3:31 pm Follow my build here: https://www.instagram.com/ivy5custom Re: CCTV through builder or leave it until handover? 5Apr 28, 2021 12:20 pm I would say wait for handover, but if possible have the builders/electrician pre-run the cables in the areas you desire so you can then hire someone to install CCTV or even do yourself, my recommendation will be Dahua you can get 6 Megapixel cameras and a recorder much cheaper then that. I recommend IPC-HDW3641TMP-AS as it has starlight technology which means if there's enough ambient light at night the camera will automatically switch over to colour. It also supports SMD(Smart Motion Detection) this function has the capabilities to detect the difference between Human and Vehicles, meaning that you will get less fault alarms during Tripwire or motion detect since it will not detect animals or moving trees but instead only trigger on Humans or Vehicles but you can disable Vehicles and have it only detect Human and vise-versa. The recorder I either recommend a NVR2108-8P-4KS2 as that recorder supports IVS functions such as Tripwire and Intrusion but it's a fan-less recorder for those who desire a bit more quite sound and a plastic housing, but you'll need to have it installed somewhere well ventilated. If not you can also get NVR4108HS-8P-4KS2 which also has the IVS function but instead has a fan and a metal case. If you desire a cheaper camera you can also get IPC-HDW2431TMP-AS(4 Megapixels) which also has the starlight technology but only different it doesn't support the SMD function and is lesser quality image. TRANTECH SECURITY WHOLESALER 26 Davies Ave, Sunshine North VIC 3020 T: (02) 8722 0348 (Syd) T: (03) 9079 5566 (Mel) www.trantechsecurity.com.au Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20712 of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and… 1 23925 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7346 |
