CCTV through builder or leave it until handover?
NVR - https://www.autrex.com.au/ivsec-nr308xa ... o-recorder
Cameras - https://www.autrex.com.au/ivsec-nc110xa ... ity-camera
Being extremely unfamiliar with any of this I'm not sure if this is a reasonable price for this type of system or i'm better waiting and doing it post handover.
Is there a industry standard brand that everyone is using or are they all much the same?
Single story? Double story? The better the info the more we can assist
Thanks, it's for a single story build.
The recorder I either recommend a NVR2108-8P-4KS2 as that recorder supports IVS functions such as Tripwire and Intrusion but it's a fan-less recorder for those who desire a bit more quite sound and a plastic housing, but you'll need to have it installed somewhere well ventilated. If not you can also get NVR4108HS-8P-4KS2 which also has the IVS function but instead has a fan and a metal case.
If you desire a cheaper camera you can also get IPC-HDW2431TMP-AS(4 Megapixels) which also has the starlight technology but only different it doesn't support the SMD function and is lesser quality image.
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
8/11/2023
1
of course there are legal avenues. You've already mentioned it. Sue them. I find it odd that lawyers wouldnt be willing to take on the case, given CCT evidence and…
19/05/2023
3
yep sounds good make the footing bigger to to allow for the pipe in the middle
