Browse Forums Increasing Home Value 1 Apr 25, 2010 7:45 pm hey we are building in the coast estate in seaford rise and have are flat block that has already been retained, just wondering if anyone else is in the same boat and has an idea of what there footings ended up costing. been given a 19000 estimate and have heard some horror stories but no ones point of view on a flat block. ????????? chad and tammy Re: footing costs in coast estate seaford rise 2Apr 29, 2010 7:13 pm well looks like ill have to answer my own question in the hope that it helps someone else. price can back at $22,000. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7363 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10330 I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. … 0 3396 |
