Browse Forums Increasing Home Value 1 Nov 27, 2009 7:27 am Should I second glaze the windows?
At times I feel like I am wasting 4.5K on the windows. I guess, I need a little reassurance that it's okay to do this! Does this add any value to the place at all? [I wouldn't be selling anytime soon] Re: Should I second Glaze the windows? 2Dec 02, 2009 9:29 am I would wait till you moved in to see just how bad it is. The secondary glazing looks quite bulky as it is just a window behind a window...and does seem quite expensive. Without knowing what type of windows they are, could you get them double glazed? This could help keep the heat down in summer and the warmth in in winter, especially if the windows are facing west. Andy Re: Should I second Glaze the windows? 3Feb 24, 2010 5:54 am Hi there, I am facing the same question I have a lot of road noise that i want to shut out. i, too, need to double glaze but I am baulking at the cost - $5k. Re: Should I second Glaze the windows? 4Feb 24, 2010 7:44 am I've got double-glazed windows and so far so good they cut out a lot of noise, and this morning it was 11 degrees outside and inside the inner pane of glass was no where near as cold as what it was outside! Great for getting a better Energy Star rated house. $5k for how many windows? It cost me more than that to option up my house with double-glaze. Re: Should I second Glaze the windows? 5Mar 27, 2010 10:23 am gantricity I've got double-glazed windows and so far so good they cut out a lot of noise, and this morning it was 11 degrees outside and inside the inner pane of glass was no where near as cold as what it was outside! Great for getting a better Energy Star rated house. $5k for how many windows? It cost me more than that to option up my house with double-glaze. it would be expensive to build a house with double glazed windows, because all your windows will have two panels stuck together with a total thickness of more than 10mm.. add on double glazing utilizes a thin plastic material that is adapted to existing windows. its less effective( generally improves heat eficiency from 2 star to about 3.5 star.) i found this on the foolowing website http://www.coolmax.com.au/ht/double-glazing.php VICTORY 1800, EN-SUITE, DOUBLE GARAGE, FAMILY ROOM AND ALFRESCO Land Settled: 20 July 2010 Site Scrap: 30 August 2010 Slab Pour: 20 September 2010 Frame Complete: 23 September 2010 Fascia and Gutters: 28 September 2010 Roof Complete: 06 October 2010 Lock-up complete: 28 October 2010 Plaster complete: 29 October 2010 Fix-out complete: 22 Nov 2010 PCI 7 FEBRUARY 2011 Hi team, Im looking for a second hand sd4b monitor preferably white. 0 8923 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37139 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8452 |
