Browse Forums Owner Builder Forum Re: Setting steel house posts in deep concrete footings 2Jan 04, 2020 3:47 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Setting steel house posts in deep concrete footings 4Jan 04, 2020 7:51 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Setting steel house posts in deep concrete footings 8Jan 04, 2020 9:56 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Setting steel house posts in deep concrete footings 11Jan 05, 2020 7:44 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Setting steel house posts in deep concrete footings 13Jan 05, 2020 8:42 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Setting steel house posts in deep concrete footings 15Jan 28, 2020 2:12 pm As said above contact the engineer and get them to re specify this as a chem set fixing as the method he has highlighted is the strongest but not the most practical, even if you suspend it well, the pouring of concrete may stuff up your set out marginally throwing out structure. Chem set fixing will involve pouring your footing to the required height, and just bolting the post down at the top. Generally engineers don't like to specify chem set fixings as there may be concerns around uplift forces, but I am yet to see this being an issue on projects I've done. Re: Setting steel house posts in deep concrete footings 17May 27, 2020 12:22 pm - Excavate to 1700mm - Pour 200mm concrete - Use 20mm non shrink grout - Bolt down base plate and post to your structural engineers spec - Pour the rest of the footing Two pour to 700mm might work as well but you need to confirm if cold joint is allowed with your structural Engineer. Re: Setting steel house posts in deep concrete footings 18May 27, 2020 12:41 pm What is your foundation design? How those posts are supposed to be linked together? With timber or with concrete? I would be second to saying that you would need to create your bearings first, prop them, attach posts to the bearings at the right height and then pour the footings with the posts being already inside them. You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7031 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14447 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8476 |
