I'm building a commercial kitchen, and found grease trap regulations for sydney, but I live in adelaide. Is it ok to just follow sydney regulations or do they change by state?
Also what would you consider a "standard" trap?
Browse Forums Owner Builder Forum 1 Dec 13, 2019 10:44 am I'm building a commercial kitchen, and found grease trap regulations for sydney, but I live in adelaide. Is it ok to just follow sydney regulations or do they change by state? Also what would you consider a "standard" trap? Re: Do grease trap regulations vary by state? 2Dec 13, 2019 12:57 pm This is the standard grease trap parameters. In terms of regulations it does vary by state, and for adelaide it depends on how much grease you'll produce. They say the max build up shouldn't exceed:
Do you have any idea, how much grease you'll produce? Re: Do grease trap regulations vary by state? 3Dec 13, 2019 1:42 pm Cheers mate, na not too sure will need to look over it again. Thanks for the tips If you have a floor waste, turn on your sink and put your ear down to the central floor waste and listen. If you can hear water running then they all connect there. If you… 10 12234 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26249 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1969 |
