Browse Forums Owner Builder Forum Re: How to shore up ground while replacing a retaining wall 2Sep 20, 2019 9:12 am Check with your council retaining walls need certification You will need Engineering drawings and details the get 3 quotes BTW, Try putting up photos with more information The better the post the better the reply and those that reply cant read minds nor guess what you require. It also helps other. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: How to shore up ground while replacing a retaining wall 3Sep 21, 2019 1:23 am thanks for the reply, I understand, that retaining walls require design and certification. My question was about possible shoring methods for temporarily retaining the dirt, WHILE I AM REMOVING THE OLD WALL and BUILDING THE REPLACEMENT. I note a neighbour, just removed all the dirt and then rebuilt the wall....luckily the dirt beside the excavation reposed at a steep angle and didn't move until the had finished the new retaining wall. I am thinking I would prefer to treat the dirt before excavation to reduce the likelyhood of the dirt sliding toward the partially constructed wall... or to use a physical retention method while the wall is being constructed. Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 11611 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 Hi all, Just wondering if anyone had suggestions on installing/replacing wall insulation on an external wall which doesn't have wrap, our miners cottage being constructed… 0 4957 |
