HelixSteel - 3D concrete reinforcement
www.helixsteel.com.au
Looks like a really interesting technology - adding zinc fibers to the concrete mix, it allows you to create much stronger 3D reinforced slabs and save tons of money on traditional steel-working labor.
They have used this technology for over 10 years in States already including many commercial structures.
They are also very helpful in converting your traditional engineering design into HelixSteel Alternative Design and provide you accurate cost estimates.
I am strongly considering to give them a try on my ground slab and retaining wall.
FYI Steel fixers charge $700 per Tonne (Perth) flat slab
OT, That is a $1m Staircase in a $25m house
BTW clients can't see your Helix..... it's .buried in concrete...get it.
Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks
15/05/2023
1
I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp
