Browse Forums Owner Builder Forum 1 May 21, 2018 8:51 pm Hello All, Just double checking before I purchase this door. Frame opening 2310 H, 1095 W. H=2310 -(22mm)-(3mm gap top)-(5mm gap bottom)-(10mm packing) W=1095-(44mm)-(6mm gap sides)-(20mm packing) Appreciate if someone can check the above. Should the packing be 10mm instead of 20mm? Thanks Re: Front door size 2Jun 06, 2018 12:25 pm NSU Hello All, Just double checking before I purchase this door. Frame opening 2310 H, 1095 W. H=2310 -(22mm)-(3mm gap top)-(5mm gap bottom)-(10mm packing) W=1095-(44mm)-(6mm gap sides)-(20mm packing) Appreciate if someone can check the above. Should the packing be 10mm instead of 20mm? Thanks I'm more comfortable using 10mm not that 20mm can't be used. Re: Front door size 3Jun 07, 2018 7:36 pm Should explain a bit further. From the lentil to the top of the jamb 5mm gap For the side 10mm each side. Using 22mm door jamb. opening 2310 H 1095W H=2310-(22mm jamb) (-3mm Gap top) (-5mmGap bottom)(-5mm packing) W-1095 (-22*2 Jamb)(-3x2 gaps sides)(-10x2 packing) door size H =2275 W=1025 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3549 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 1187 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24822 |
