Skillion Roof Insulation
Looking for some ideas on insulating a Skillion roof on a shed for maximum R value, the roof is constructed with 200mm C purlins, 40mm top hat and 22mm ceiling battens.
I know that the recommended procedure is to put on Anticon above the top hats and let it sag down from the Colourbond sheet but WHY not stretch it over the C Purlins and fix it under the top hat?? am I missing something here?, it would look a lot better, whats the catch?.
My thought would be from top, Roof sheet, Anticon, 25mm gap, Batts, and then gyproc, any body got any other suggestions?
TIA
Colin
Dims
It's metal sheet cladding-> Anticon-> Metal Roof battens-> Metal CPurlins -> Metal Ceiling battens->Roof Insulation-> Gyprock Ceilings.
Why
1. Safety
2 Cost
3.Ease of Placement
4. Minimise condensation
5. Break Thermal bridging to minimise gyprock/ceiling cracking
BTW I would add in another layer of insulation ie batts
Also give some consideration to fixing plasterboard that allows thermal movement Of metal & Non metal materials hth
Hi It's metal sheet cladding-> Anticon-> Metal Roof battens-> Metal CPurlins -> Metal Ceiling battens->Roof Insulation-> Gyprock Ceilings.
Why
1. Safety
2 Cost
3.Ease of Placement
Regarding the Anticon, I realise that the fitment wouldn’t be as easy but had noticed in a lot of roofs that in the early morning you can see the condensation sitting between the battens and thought surely this is not the best option.
Am I right that a 25mm gap is necessary between Anticon and batts? Therefore maximum batts thickness would be 175mm in my case?
Cheers
Colin
Not sure about an air gap between The anticon and Batts as I think it has minimal effect
You might find this resource useful
Lysaght Installation Roof Manual
Hi All,
TIA
Colin
TIA
Colin
insulation in australia is a flawed and poorly executed science.
3 keys to insulation
airgap , airflow , thermal barrier
TIA
Colin
it really is hard to elaborate as every building is unique. but having a greater r value does not gurantee your job will be insulated better.
on compact roofs i believe the best way to insulate is to have insulation as thick as possible above the plaster ceiling then at least a 50mm airgap and also a way for the air to be moved in that gap (most important). i.e whirly bird and vented eaves
125mm sips panels and the house with 210mm sips panels. Both have skillion roofs so the shed was the experiment before moving onto the house a few months later. I would appreciate any further ideas as this is a dream OB project of mine and would hope to get it right. It was designed with Solarspan but due to difficulty running services, thought I would look for other ideas especially for the shed as there aren’t any false ceilings.
Thoughts?
Cheers
Colin
Why? Because I want to and I can😜
Cheers
Colin
1
Why don't you call and talk with someone at the town planning in your council?
15/06/2023
Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like…
6/07/2023
2
1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it
