Browse Forums Owner Builder Forum 1 Mar 30, 2018 11:26 am Hi, I've got the plans finalised for a small house and am hoping to start building in the next couple of months. I've had three quotes from builders for building to lock-up stage, ranging from $120,000-$130,000, so fairly close to each other. Have been told by one of the builders that the slab should be about $20,000 of that, so $100,000 or so for the rest of the work to lock-up. I'm trying to understand a breakdown of costs to see if there are significant savings to be had by managing it myself. There seems to be from what I can estimate but with no experience I may be overlooking and underestimating a lot of things! It's a two-bedroom house, 100 m² of living space with 40 m² of carport (under the same roof). The layout: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I've got quotes for some of the work, have a rough idea for other parts, and no idea for the rest. This is what I think t I have a reasonable idea of: slab price from builder: $20,000 trusses from local hardware store estimating service: $5000 framing timber from what I have modelled (with hardwood studs, Bunnings retail price): $5000 beams from local hardware store estimating service: $1000 colorbond roof, gutter and fascia with blanket insulation installed quote from local roofer: $10,000 building wrap from local hardware store estimating service: $1000 windows, 2 aluminium door frames and large sliding door supplied: $8500 external hardwood doors: $1000 Stria cement sheet cladding from local hardware store estimating service: $7000 That comes to somewhere around $60,000. And things I don't have much of a clue about: labour for framing and truss erection labour and materials for windows and doors installation labour for building wrap and cladding, plus painting the cladding downpipes plumbing temporary power, water, portaloo etc Could those things account for most of that $60,000-$70,000 difference and/ or am I forgetting some major costs? One of the builders I was talking to said if I employed him on an hourly rate it would be $60 for his time and $40 for his labourer. Super rough estimate for costs to install cladding: there are approximately 60 boards required for the house. If it takes half an hour for each board to be installed that's 30 hours at $100 an hour, so $3000. Is framing and erecting trusses crazily labour-intensive? Thanks for any advice! Re: Ballpark costs for building 2Mar 30, 2018 12:36 pm Heliosphere Who did your plans, chances are they might have been modelled in a 3D BIM Software package ie sketchup...Then you need to break down the elements ie slab ->components->material,labour planning -> Compare Getting the best Info, Data and use from a site/project Post back with more Info Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 4Mar 30, 2018 4:17 pm Then you will need to do a manual takeoff and put it in a spreadsheet Use Google sheets Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 5Mar 30, 2018 8:14 pm I don't think I need anything too detailed, just rough ideas about the labour involved really. Is framing a basic small house a job that takes a couple of people 1, 2, or even more weeks to do? If it's a couple of weeks then I guess it should cost less than $10k. Making further guesses, putting in windows, wrapping the building and nailing on cladding should cost less than $10k (hopefully significantly less?) Even allowing another $10k for the other things I mentioned and things I might have forgotten I'm still $30k away from the quotes I got. What am I missing or underestimating? Re: Ballpark costs for building 6Mar 30, 2018 9:27 pm Don't...Guess work it out Wall Framing (Plates-Studs-Noggings) 1 Tradie + 1 Labourer will do approx.100m2 in 20 hrs Plus extras allow the same for sheathing. 3D Bim software automates all the details (Studs,plates,noggings) , calculations & costs.. but I suggest you use a spreadsheet and m2 Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 7Apr 12, 2018 9:25 pm Hi mate, how’d you go with pricing? We have a similar sized build (150 SQM) but are looking at kithomes. $75k for kit, kit home guys reckon you could do an owner builder and have it built for another $90k Kit doesn’t include slab, plumbing or electrical. Would be interested to see how you went with labor cost if you project managed. Cheers Re: Ballpark costs for building 8Apr 15, 2018 9:11 am Get extract prices, for building materials by 1. Having your design modelled in 3D Bim Software 2.All material can be estimated from within the 3D Bim programs 3.Use the data and costs to make informed decisions. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 9Apr 15, 2018 2:09 pm If you have had 3 quotes in and around $130,000 then that is what it will cost to build up to lock-up. I have my own business and work with a number of residential clients. You can see a snippet of the breakdown of costs here for a brick veneer home in Sydney - https://imgur.com/F1nf8pT As StructuralBIMGuy stated, you will need to undertake a detailed Cost Summary to understand where you sit and how much the build will cost if you do go the owner-builder route. You will need to include a cost for your time if you do go down the owner-builder route as well. Re: Ballpark costs for building 10Apr 15, 2018 3:47 pm Thanks for sharing % Breakdowns, that is one method of cost analysis another is to break it down to base materials accurately ie, l/m, m2, m3 and apply realistic labour rates and constants, Alternatively You can breakdown builders online prices, solve for variables and and use that data to analyze your design...But you need designs first for comparison purposes.hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 11Apr 15, 2018 9:59 pm StructuralBIMGuy Thanks for sharing % Breakdowns, that is one method of cost analysis another is to break it down to base materials accurately ie, l/m, m2, m3 and apply realistic labour rates and constants, Alternatively You can breakdown builders online prices, solve for variables and and use that data to analyze your design...But you need designs first for comparison purposes.hth Hi StructuralBIMGuy, That was just a snippet of a report for a detailed cost plan that was prepared for a residential client. All costs for that project were broken down elementally. The percentages on that cost summary are only specific to that project, with costings priced for the Sydney market. Re: Ballpark costs for building 12Apr 16, 2018 8:46 am Not sure what work you do? But unless you do the entire AEC model in stages yourself the work becomes repetitive, tedious and difficult to automate with computer algorithms Perth housing is 15% cheaper for Double brick and concrete Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Ballpark costs for building 13Apr 25, 2018 9:52 pm Heliosphere I don't think I need anything too detailed, just rough ideas about the labour involved really. Is framing a basic small house a job that takes a couple of people 1, 2, or even more weeks to do? If it's a couple of weeks then I guess it should cost less than $10k. Making further guesses, putting in windows, wrapping the building and nailing on cladding should cost less than $10k (hopefully significantly less?) Even allowing another $10k for the other things I mentioned and things I might have forgotten I'm still $30k away from the quotes I got. What am I missing or underestimating? builders margin , its a fee they charge because people dont understand how much and how long it takes to build a house Re: Ballpark costs for building 14May 02, 2018 11:30 am Look at "Rawlinsons-Construction Cost Guide" for the area you intend to build. There is a section for building cost per sq meter- that would be a rough guide. Do a takeoff for more detailed costing Good luck consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 4634 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 8270 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 3981 |
