Browse Forums Owner Builder Forum 1 Jan 28, 2018 7:59 am Above the garage opening there is a PFC 380 with a plate welded 200mm. (the brickwall is 230 on either side of the beam). Half the garage will have a single roof the other half brickwork going above to the second storey. Question brickwork on inside the beam does it need to be from the bottom or top of the beam? If bricked from above the beam there will only be 3 to 4 courses. Is that enough to hold the roof? Thanks Re: Garage Beam Brickworks 2Feb 04, 2018 7:02 am NSU Your engineer will advise you of the options for non-Standard beams ie Section, materials, loads , Span, deflections.etc,etc. It's also hard to comment without seeing details, but if you don't want to see the beam, then the brickwork will sit on the bottom flange, Lip. More info required for the roof part question? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12871 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27305 |
