Browse Forums Owner Builder Forum Re: My New...ish house in Toowoomba build story 62Feb 19, 2011 12:17 am Well It's been awhile, so here is the latest update... With pics! The panaling outside got finished Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then the joins got filled Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then finally the rendering was done. First coat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ second coat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then window trims glued on Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then it was painted to match Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ followed by the downpipes Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then lower half of the window, door trims and the moulding around the house where all glued on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Finally complete! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Next some of the cupboards for the kitchen where installed, base for the cupboards Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the start of the cupboards Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ so that the elevated pipework could be installed inside the pantry, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then the framing for the bath was started, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then the floor was poured and shaped. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then the wetseal Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ as well as that the rooms got painted first under coat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ then colour, same colours for all rooms (full strength hogsbristle with ceiling white) except bathrooms and wardrobes. (full strength silverwater) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and light fittings installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Next the cypress floors upstairs and staircase were polished and then architraves and skirting boards are now being stained and nailed in place. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ as well as the bar started to go in. just waiting on the benchtops now, and to figure out what i want to do with the doors. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Bathroom was tiled Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and fitted out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Now the list is down to: finish nailing skirting boards and architraves on upstairs, finish tileing the upstairs toilet, finish off the walkin robe, finish the varandah and patio, install all the doors on the bedrooms and bar cupboards and install the bar benchtop Then upstairs is complete Downstairs needs to have the sheeting finished, suspended ceiling to be installed painting, kitchen and laundry cupboards finished, floor to be tiled (except study and theatre rooms that get carpet) skirting and architraves thru out. Then it's just the back patio and driveway to be concreted! and then finally it's relaxing time!!!!! My Owner still Building thread viewtopic.php?t=9026 Re: My New...ish house in Toowoomba build story 63Feb 19, 2011 10:03 am well well well aweeeeeeeeeeeeeesomeeeee absolutely loving it all great job bet your glad its nearly over. youve done a fantastic job and after seeing your blueboard rendered im glad we stuffed up our weatherboards cause i love the rendered look lol congrats mate stay safe happy building Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8556 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4124 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17949 |
