My brickies have started on the base for the infill slab and suspended bondek (1m)
75% infill and 25% suspended bondek.
Question- what are the requirements for below slab?
Weeping holes?
Air brick? (Vent)
We are in area with Bal 29.
Thanks
Browse Forums Owner Builder Forum 1 Oct 03, 2017 7:21 pm My brickies have started on the base for the infill slab and suspended bondek (1m) 75% infill and 25% suspended bondek. Question- what are the requirements for below slab? Weeping holes? Air brick? (Vent) We are in area with Bal 29. Thanks Re: Infill slab and Bal 29 3Oct 03, 2017 7:42 pm Thanks for the quick response Not concerned about the bondek. The external brick wall requirements below slab. The brickie says weeping holes are required above slab level. Air vent what are the requirements in a Bal 29 area? Re: Infill slab and Bal 29 4Oct 04, 2017 9:36 am Don't you have Engineering & Construction Details... what was approved for Building? I wouldnt leave the venting up to your bricklayers your home insurance will be void if it's Non-Complaint Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Infill slab and Bal 29 8Oct 06, 2017 8:01 am NSU
Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5228 3 4113 |
