Plywood or particle board floor
Time to order materials for subfloor
striaght forward question
Plywood vs particle board flooring - which should we go with and why?
Flooring will be carpet in bedrooms, spotted gum most places, tiles in wet areas ex kitchen
I am concerned though that we might not get a roof on by xmas and the particle board will be exposes to elements over dec / jan breaks
bearers + joists going in today - should be done by mid next week and floor to go in early week after, once plumber and sparky are finished the first parts of their rough ins
Frame to go in straight after
need bricklayer back + steel install before roof trusses can go in
should take a few days for them to go in and then we are ready for sarking + tiles
that by my calcs is around 17/18 Dec i.e. if we lose a day or two along the way - little chance roof is on pre xmas /new years breaks
would you be concerned about water damage of particle board if it was exposed to elements for 3-4 weeks??
If you seal it well that should be enough to protect it, if you don't mind a bit of paint on it I would seal it (underside too).
all the best
Pete
ie the plastic will be there forever under the frame?
The plastic then stays until the house is painted (just before the carpet or tiles go down this protects the floor from building adhesives , paint etc and if you are too broke to put carpet down it gives you a reasonable floor to live on.
When the building is finished it is a simple matter of running a stanly blade around the rooms to remove the protective sheet.
Pete
If the roof will not be ready consider using galv nails with treated flooring as normal nails will rust very quickly.
My own OB proceeded very slowly so I used galv fasteners everywhere
Thanks guys
no it will be fine , it has a wax coating on it that will protect it easily for that amount of time
yes it is possible that the floor may be damaged by inclement weather, I would get a roll of thick black poly plastic from Bunnings and cover the floor with it (get quality adhesive tape to join it).
all the best
Pete
all the best
Pete
do not do this you will get mould , in 18 years as a carpenter i have never seen this done , black poly and weather around timber equals mould mould mould
1
Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon
7/03/2024
7
Thanks for clarifying. Sorry I misunderstood your point
12/06/2023
CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.…
