Browse Forums Owner Builder Forum 1 Sep 25, 2017 9:47 am Hi all We are hoping to install secret nail cedar boards in our living/kitchen ceiling and in our alfresco areas, has anyone done this with a steel frame? Would you fix timber to the battens first? Any other suggestions? Very possible that I am wording this incorrectly, my husband is 'builder'! Thanks for any advice! Jude Re: Installing cedar ceiling lining on steel frame 2Sep 26, 2017 10:05 am tjwoody Hi all We are hoping to install secret nail cedar boards in our living/kitchen ceiling and in our alfresco areas, has anyone done this with a steel frame? Would you fix timber to the battens first? Any other suggestions? Very possible that I am wording this incorrectly, my husband is 'builder'! Thanks for any advice! Jude Re: Installing cedar ceiling lining on steel frame 3Sep 26, 2017 10:41 am Searching4 knowledge tjwoody Hi all We are hoping to install secret nail cedar boards in our living/kitchen ceiling and in our alfresco areas, has anyone done this with a steel frame? Would you fix timber to the battens first? Any other suggestions? Very possible that I am wording this incorrectly, my husband is 'builder'! Thanks for any advice! Jude I would attach it to battens. For a start you can straighten the alignment so the finish is flat and will be a lot easier to attach the boards to battens at the correct spacing than the steel. Thankyou! Re: Installing cedar ceiling lining on steel frame 4Oct 15, 2017 1:29 pm tjwoody Searching4 knowledge tjwoody Hi all We are hoping to install secret nail cedar boards in our living/kitchen ceiling and in our alfresco areas, has anyone done this with a steel frame? Would you fix timber to the battens first? Any other suggestions? Very possible that I am wording this incorrectly, my husband is 'builder'! Thanks for any advice! Jude I would attach it to battens. For a start you can straighten the alignment so the finish is flat and will be a lot easier to attach the boards to battens at the correct spacing than the steel. Thankyou! Absolutely correct. Good advice. Re: Installing cedar ceiling lining on steel frame 5Oct 28, 2017 7:05 pm make sure all the roofing is covered with some sort of barrier to prevent condensation dripping onto the cedar. Its always better to coat the side that goes towards the roofing material too. Helps prevent warping, but cedar is pretty stable. Re: Installing cedar ceiling lining on steel frame 6Apr 25, 2018 10:17 pm tjwoody Hi all We are hoping to install secret nail cedar boards in our living/kitchen ceiling and in our alfresco areas, has anyone done this with a steel frame? Would you fix timber to the battens first? Any other suggestions? Very possible that I am wording this incorrectly, my husband is 'builder'! Thanks for any advice! Jude use timber battens Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8036 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3426 |
