Browse Forums Owner Builder Forum Re: Our Kitome Glenbrook - We've Moved In! 121Jan 27, 2010 4:49 pm Thanks serialstyler. I hope we've got the absorption pipes set up right. We should hook it all up and see how we did. The back deck is just about done. We ran out of screws before we could get the last few boards on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - We've Moved In! 122Jan 28, 2010 10:39 am I just found your thread and plan to read the lot! tonight when I have some time. Your house looks amazing and I am interested in how long it has taken you from the beginning to now, so when did you start building. Also have you built the home by yourself?? Sorry one more thing you have moved in now and have a few more things to do, yes?? Would you recommend finishing the job completely before moving in because I would love to do that but hubby wants to finish completely....not sure how long that will take though! Cheers Michelle Re: Our Kitome Glenbrook - We've Moved In! 123Feb 02, 2010 1:11 pm Hi Michelle, Thanks for the rap, we're loving the place. As for how long, we started turning dirt for the house in Feb 2008, and moved in on June 26 2009. So 16 months from start to move-in. When I say I built it I couldn't have done it without my father-in-law and my fathers help. These old blokes know a thing or 2 about this. We moved in with quite a bit still to do. And once we'd moved in things did slow down. But then we had to chase an 8 month old and 2 year old and work around their sleeping once we were in too. We're happy we moved in before it was done, we just plug away at the little jobs as we go. And it sure beats living with the in-laws Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - We've Moved In! 124May 05, 2010 3:11 pm Little bits and pieces have been getting done around the place. Dunno if the list is getting any shorter though Finally managed to get a couple of coats of stain on the deck. Only 2 years too late. Went for a Merbau one to hopefully get some colour back into the boards. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My dad and I had a weekend at the verandah lining. Just needs some quad on it now, but you can't rush these things Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And just when I thought I'd finished painting doors, my wife comes home with 2 new ones for the front and back. Out with the brushes again Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - We've Moved In! 125May 05, 2010 3:15 pm And we thought we'd better do something about getting the garage up and going. So we got a guy in to move some dirt around and dig some holes. Before Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All flat Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Beams and piers dug. There were some big piers at the back cause the site was all on fill. Only 3m holes in the back corner! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And because the holes were so deep, and the concreter wasn't available till the next week, we filled the holes to stop them falling in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And got a load of steel ready to put in. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - We've Moved In! 126May 05, 2010 3:19 pm After a weekend of setting up the formwork, plastic and steel we were ready to fill it up. It was at this stage I realised I'd made the beams 100mm too deep, so had to order more concrete. And for some reason the front ended up looking very thick, even more concrete! Ready to fill up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First and last loads. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the finished slab. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ended up taking 10.2 cubic meters Ah well, with all that concrete, the massive piers and truck load of steel in it, it shouldn't go anywhere! <touches wood> Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - We've Moved In! 127May 31, 2010 1:38 pm We've now built some frames and got them stood up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also whipped up a few trusses too. We ran out of gang nails before we could finish them, and there is a 2 week wait to get more big ones. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ In the meantime I've been sorting the tie down bracing, sticking dpc under the frames and getting the tie down bolt holes ready. While dodging the rain. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage in Progress 128Jun 01, 2010 10:36 pm Looking good, Pete. You've been busy! Life's too short too drink bad wine Re: Our Kitome Glenbrook - Garage in Progress 129Jun 18, 2010 1:40 pm There always seems to be something to do Hammerhead Pity the to-do-list doesn't seem to ever get shorter, only longer! Bolted the frames down Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And chucked all the trusses up. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage in Progress 130Jul 21, 2010 1:00 pm Got the roof battened out so that the roofer didn't have to do it. And with some help from my wifes uncle and my wife we got the timber facias up. I also stuck some sheet brace on the front wall to try and firm it up a bit too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage in Progress 131Jul 21, 2010 1:06 pm And then Luke came down and we had a great weekend for putting the roof on. Facias and gutters on. Barge roll in progress. Some bozo (ie. me) ordered gutters that were too short. Dunno how I managed that when the facias and ridge cap were right. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just used the sarking that we didn't use on the house. Didn't even go through a whole roll. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the roof all done I'm really happy with it... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ...apart from this bit Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage Cladding 132Sep 07, 2010 12:56 pm Progress on the garage has been a bit slow with a few social events creeping in on weekends. But we've got nearly all the cladding done. The wiring is roughed in. And the roller doors, motors and pa door are ready to fit too. Hopefully another couple of weekends at it will see it done, or usable at least. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage Roof On 133Sep 07, 2010 2:23 pm Hi Pete, Did you get one of the kitome garage kits also? If so roughly how much was it, Ive just bought a block of land and am looking at sticking a garage up just so I have somewhere safe to lock my tools up whilst I build the house. Also how were kitome to deal with? I have been looking at their Hartly home for some time Re: Our Kitome Glenbrook - Garage Roof On 134Oct 05, 2010 8:13 pm Awww so jealous!!! It's beautiful! We are going to go through Kitome too. We like the Harrington MkIII. First hurdle for us though is to get owner builder finance.....sigh.... Seriously, well done on your build. It is wonderful! Wooo! I have a thread! https://forum.homeone.com.au/viewtopic.php?f=38&t=39239 Re: Our Kitome Glenbrook - Garage Roof On 135Oct 11, 2010 2:44 pm Gday Tubbym, sorry for the late reply, I've sent you a pm just in case you don't check back in here again. And thanks Bendnsnap. I've heard its getting harder and harder to get owner builder finance. Good luck with it, hope you get a result soon. We got ours with Newcastle Permanent building society, and that was about our only choice in the end. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage Roof On 136Nov 05, 2010 1:45 pm Looks great Pete, would love something like that for myself one day (don't fancy building another do you- j/k) Re: Our Kitome Glenbrook - Garage Roof On 137Jan 13, 2011 3:41 pm Wow, its been a while since I updated this. Shows how slow things are moving here at the moment. Back in September last year we insulated and lined the walls of the garage. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Got the lights and power hooked up Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Did lots of filling and sanding and filling and sanding again. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Got a coat of paint on the outside and put the doors on. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And finally just the other day we got the cornice up and whacked a couple of coats of paint on it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And there is always plenty of grass to mow, especially with all this rain and humid weather. I just have to pick when its dry for a bit so the mower doesn't get bogged on the hills Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And that's about where we're at. We're trying to get a bit of landscaping planned out, and we really want our driveway concreted. But we're kinda out of funds now so these will have to wait. Cheers, Pete viewtopic.php?f=38&t=8824 Re: Our Kitome Glenbrook - Garage Roof On 138Jan 13, 2011 4:20 pm What a beauitful setting,home and garage look very nice.Nice place to bring up children and retire. Our Kitome Glenbrook - Garage Roof On 139Jan 13, 2011 9:39 pm You've done brilliantly Peter. We have finally moved in to our Harrington mk III. Still so much to do so few funds. Definitely understand the driveway bit. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Re: Our Kitome Glenbrook - Garage Roof On 140Jan 13, 2011 9:51 pm Cant belive Ive missed this! It all looks wonderful Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! I would probably definitely consider contrasting out garage door (e.g. light ash would look great) and make downpipes and fascia same colour as your walls, not as your… 1 3569 Building Standards; Getting It Right! Hi all I’m in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11712 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9617 |
