Browse Forums Owner Builder Forum 1 Jun 11, 2017 7:53 pm There are so many types of anchors available: Theres coach screws into a ramset plastic plug, theres dynabolts, theres ankascrew masonry screws. What would be the most suitable method to fix 120x45 pine to a clay brick wall? The pine is for a ceiling frame. Re: Choice of anchor into brick? 4Jun 13, 2017 7:32 pm My concern with the Ankascrews is they could be brittle. Because they are threaded directly into the brick, vibration over time could erode the brick and loosen the screw? Where as a dynabolt or a plug relies on pressure all along the shaft. If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 6096 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 4582 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 8158 |
