Browse Forums Owner Builder Forum Re: have you ever heard 'timber truss solution' in Melbourne 2May 22, 2017 3:36 pm Regarding pre-fab wall frames, I have a concern, if it totally depends on the engineering plan, not on the site measurement, I will fall into trouble that the pieces of wall frames cannot be assembled after being delivered because there will definitely be deviations between actual dimensions and what it draws on the plan. Regarding the roof trusses, someone suggests making an order after the wall frames have been erected, so that the roof manufacturer can come over to measure the actual size and make roof trusses accurately. Re: have you ever heard 'timber truss solution' in Melbourne 3May 24, 2017 8:23 pm I would be concern about other issue like timber expansion / shrinkage due to conditions of the actual site. ie: moisture. These are things that might not be prepared during the prefab process. I do believe that it is better to let timber rest on site for at least a week before start using them. If it is steel truss and frames, I wouldn't have these concerns. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2214 Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3551 |
