Browse Forums Owner Builder Forum 1 Apr 24, 2017 5:36 pm Hi We are building our property and are looking very closely at the above for a building material for the outside of our home. It looks very good and the reviews we have seen states its very good for noise and heating and cooling. Does this cost more than bricks or less, not sure as I don't understand the lengths and all, can't hit a nail in straight, would building with this also mean that to lock up stage would be quicker? Also there are alot of different types of this cladding, is there another one we should look into other than the Scyon Stria? Thanks in advance Steve Re: Scyon Stria cladding 2Apr 24, 2017 7:35 pm I doubt it would be that much quicker than a competent bricky gang. Depends on the look you're after and the style of house. Cheaper if you're talking 2 storey or if the builder puts it up with his own framers. There is no right or wrong answer Plenty of other cladding options but they're getting quite expensive i.e. cemintel designer series. Re: Scyon Stria cladding 3Apr 27, 2017 3:40 pm I just finished a build using this stuff. In my experience it's definitely cheaper than brick. Solid feel and very good for noise and heating and cooling but this also depends on the insulation you use. It can be faster especially if your frames and trusses are built off site while you get the slab ready. That's what we did. Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12046 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11117 Re my second point – yes exactly. And often it may take additional time if the manufacturer recommends no more than X meters… 3 5643 |
