Concrete Raft Slab Melbourne
We had one very experienced guy who unfortunately isn't well at the moment or else we'd use him in a heartbeat. He let us know what we should be paying, but those that are quoting are at least 25% higher than him. He said that there's so much work on at the moment that people will put outrageous quotes out there to see if anyone bites.
Does anyone have a slab person they could recommend that doesn't try to rip you off?
Being ripped off is one thing getting a lousy job would be my main concern.
BTW you will find most tradies will inflated jobs by the builders (25%-50%) margin for owners builders
Unfortunately, there is really little savings unless you choose to do some of the work yourself
Goodluck
I got a neighbour to cut the site & construct the access track using his dozer, based on an agreed hourly rate. He also carted road base using his truck, again at an hourly rate plus the cost of the quarry materials.
I got someone else to prepare and compact the slab base, this time at an agreed price.
I set the slab out and then I got a local builder to excavate the trenches at an agreed hourly rate. I was on hand to manually clean the trenches out.
I got someone else to place the reo etc and then got a team together to pour the slab based on a fixed price for labour whilst I paid for the materials .including the concrete.
I hired and paid for the concrete pump directly.
I also got a local plumber to install waste pipes and I arranged for a pest control company to carry out termite treatment.
I summary whilst I could not get a price from a single contractor to organise and construct the slab, I was able to subcontract out most of the work, managed the process and took the overall responsibility and risk.
Start with the Design Engineering, Data, Quants, Labour rates, factors, simulations, proofs, certification,compliance
and use online apps to automate decisions & make informed decisions.. leave a message if interested
I also had under estimated the quantities of quarry products and concrete that I actually needed especially the amount of road base required to construct all weather truck access and turn around areas before I could start any building work on site.
I also had the cost to repair the access tracks at the end of the build.
1
The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists.
15/12/2023
1
yep, clearly mark where the infloor heating pipes are before drilling or nailing
13/03/2024
1
is this for a residential dwelling or a shed? If its for a dwelling, its out of tolerance and a "mistakes happen" isnt a good enough excuse to just move on.
