900mm vs 600mm Eaves
The house is going to be a long ranch style house with a hipped roof, similar to Metricon's Denver (http://www.metricon.com.au/new-home-des ... MqYyO7A.97).
Can anyone comment, or better yet have pictures, of a hipped roof house having 900mm eaves? I guess our main concern was that the eaves will overhang too much making the roof look like a hat.
Thanks
Here's a couple of diagrams in a thread or two re - shading and eave heights.
viewtopic.php?f=31&t=78233
viewtopic.php?f=53&t=73404
Don't forget also that with wider eaves your eaves height will be much lower as opposed to a narrow one.
Stewie
600 eaves are ideal for that type of home
5
My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance >
18/02/2024
1
Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it…
7/07/2023
7
Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out…
