Browse Forums Owner Builder Forum 1 Feb 03, 2016 5:05 pm Hi, Just wondering if it is important to do the render first before the eaves? We were told that's the case. I looked at the new build threads and it seems it does not matter. I guess maybe because it is easier for the renderer as the eaves will hide the rough edges if done after. How was it with you? Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: Render or eaves first? 2Feb 13, 2016 11:04 pm Render first so the trade can go past the eave line not damage the eaves ,, Re: Render or eaves first? 3Feb 14, 2016 12:17 am Yeah, we will render first before putting the eaves. Cheers! Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5835 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7822 |
