Browse Forums Owner Builder Forum Re: Frame inspection 2Nov 07, 2015 5:28 pm Hi. The frame is to be inspected prior to it being covered by any floor, wall, roof or other building element. We were advised by our certifier to have the inspection done once the roof was loaded. This was after our brickwork. Hope that helps but if unsure contact your certifier to double check This is 100% true. You can not hang anything on steel frames. very frustrating 8 8052 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98695 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5351 |
