OB in SA
Page 27 of 52
You seem to be getting a good finish on your first room, good luck with the rest of your house.
The outside walls will be a challenge as you need to keep a wet edge as you work along the wall. This will be tiring for just one renderer..
We are only rendering the outside walls and the only thing inside is the garage piers. Will see how hombre goes doing the outside wall tomorrow.
We are very happy that we can do it ourselves it seems. And be happy with the results. We were quoted $30m2 but it became $50m2 because we have different bricks throughout the house. If we are able to do it ourselves, that's a lot of money saved there. More to spend somewhere else!
Yep, we are doing the sides and the back of the house first. So hopefully when it's time to do the front, it will be flawless. Haha!
Wow, he's certainly very skilled, seems to be doing a great job at all he turns his hand to
Cheers Marshall! He was a bit worried about doing it. So we thought if it didn't work and not up to the standards*, we will pay someone skilled to do it. Very happy, it actually came up a treat.
*our standards, might not live up to to others'.
I ended up using a sponge float on my build. It gave the best results for me. (I tried steel & wood floats but my attempts with these were a fail). I really liked the results I got with the sponge float but timing was everything.
Hombre actually is happy with the finish of the sponge float. It's me that is wanting a bit more smooth finish. See what we end up with between the two. We also saw on YouTube that they used a plastic float. Not sure we will try that.
I did use a large plastic float before the sponge float. I used a steel float to initially apply the render, then wood or plastic float to smooth the wall, and finally, after the render had started to go off, I use a sponge to finish. I also filled the mortar joints the day before I starting the rendering.
Yep, will do the same thing in terms of filling missing mortar joints.
Beetaloo, would you mind posting a close-up pic of your rendered wall? I know you used cement render not the granosite material but would like to see the difference. I know ours is only the first coat and Hombre will try to make the final coat more refined, but I am not too sure if I am happy with the textured finish. Causing a little bit of friction at home. Lol! I am just wondering if the top coat should use a different product if I expect a bit of a smoother finish.
Also, if anyone else has used granosite (whether DIY or applied by a pro), would appreciate if you have photos to share.
Cheers!
Cheers!
I like the textured finish. The wall also has some bumps where some bricks were sticking out a bit. I like the rustic look. It suits my house. I did however use steel angles in all external corners. This allowed me to have nice straight edges at corners.
Unpainted walls
Beetaloo. Appreciate your reply. It looks good. I might be just panicking a little. Will wait how the final coat turn up for us. I might be OK with the textured finish.
Cheers for the photos Our sample stone colour for the kitchen and grey is our kitchen cupboards too.
Also got our washer and dryer
Our dishwasher and the rest of kitchen stuff required for cabinetry have been dropped off yesterday to the kitchen mob.
Exciting times ahead!!!
