Browse Forums Owner Builder Forum 1 Nov 13, 2015 10:19 am Hello all, Can anyone tell me if an owner builder licence for a project has a time frame attached to it? Or does it last until the project is completed? Also I'm wanting to build a detached garage/shed/granny flat as part of the build. Does an owner builder licence include this detached building along with the primary building or are they classified as a separate build? I'm located in Brisbane. Cheers Re: Owner Builder licence time frame to complete works? 2Nov 13, 2015 12:28 pm The time limit is imposed by the Council when they grant the development permit. In my case it is two years from the date of decision. You are allowed to build a shed without any permit if it is less than 10m2 in floor area and lower than 2.4m height. Ring the local council to confirm this. Re: Owner Builder licence time frame to complete works? 3Nov 13, 2015 2:11 pm Speaking from memory of NSW some years ago, it could include outbuildings as long as it's all on the same application and same block of land. I was able to build two houses on one owner-builder permit, as they were both on the same block as a dual-occupancy. A detached building should be fine, as long as it's approved by council as part of the same development. I also recall you could get an extra permit to do more work on the same site without waiting for the normal time gap between permits. Re: Owner Builder licence time frame to complete works? 4Nov 13, 2015 5:12 pm Dont confuse your owner builder licence with your building application licence. No state mentioned as usual, so I will give Qld specific information. the OB permit will run for a fixed time - it s has nothing to do with your project completion time. In qld they are valid for 6 years and one project. If you finish your project early you can still use the OB permit on further work on that particular project but no others. If your OB permit lapses you cant work on your project until you get another one. Like building permits, the state will happily take your money for another one, ad infinitum. The building application permit is usually 2 years. There is no overall time limit per se, as when it expires, all councils will readily take your money again for another application. The only situation where there are time limits are in covenanted estates, where the covenant wants you to be finished in a certain time frame. A garage doesnt require an OB/builders permit. Not unless its huge and the work to erect it would come in over $11000 (or whatever the limit is in other states) . Re: Owner Builder licence time frame to complete works? 5Nov 15, 2015 12:04 pm Thanks for the replies. We were wanting to build the Granny flat first to move into while the house gets built. I was wanting to owner build the granny flat but I am unsure whether I want to OB the house as well. Potentially I might get a builder to do it to lock up and then go from there. I just wanted to make sure that I didn't use my one six-yearly permit on the granny flat and then decide I want to do the house as well. I guess I'll just apply to OB the whole project and then decide whether or not to OB the house when I get to that point. Assuming I can do it that way. Re: Owner Builder licence time frame to complete works? 7Nov 17, 2015 10:03 am chode1984 I guess I'll just apply to OB the whole project and then decide whether or not to OB the house when I get to that point. Assuming I can do it that way. That's the go ! ... if you decide to OB the house, you won't be able to if it isn't included upfront, i.e. you'll have to wait 6 years before you could apply to do it. Enjoy your OB experience. I enjoyed my OB experience. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Fair Trading can issue orders to rectify and complete but once the matter goes to NCAT these orders are automatically vacated. You will have to terminate contract and sue… 21 30536 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 24516 |
